Vertical menu - Cannot access protected property joomla\CMS\Menu\MenuItem::$params
WebIm
WebIm posted this 08 August 2022
Joomla 4.1.5
PHP 7.4
Themler theme v556
0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params when vmenu module position is active. Depublish and there is no error
Please help!
Daniela
Joomla 4.1.5 PHP 7.4 Themler theme v556 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params when vmenu module position is active. Depublish and there is no error Please help! Daniela
14 Comments
WebIm
WebIm posted this 19 August 2022
Greetings
is there any news here?
tks
daniela
Greetings is there any news here? tks daniela
elia20
elia20 posted this 26 August 2022
Follow
Follow
Support Team posted this 30 August 2022
We couldn't reproduce the issue with the vertical menu with the latest Themler version. Could you please try switching to PHP 8 - the version recommended for Joomla 4?
Hello, We couldn't reproduce the issue with the vertical menu with the latest Themler version. Could you please try switching to PHP 8 - the version recommended for Joomla 4? Sincerely, Nettie
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 28 June 2023
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator:
Wouldn't it be possible to fix at least this error?
That would be great.
Thank you so much for your help.
Thankful
Thorsten
Werbeagentur Schulz-Design e. K.
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator: 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params Wouldn't it be possible to fix at least this error? That would be great. Thank you so much for your help. Thankful Thorsten [Werbeagentur Schulz-Design e. K.][1] [1]: https://www.schulzdesign.info
rickrode37
rickrode37 posted this 30 December 2024
To fix this issue, you need to use the proper getter method Ragdoll Hit or access the property in a way that's allowed by Joomla's object-oriented structure.
To fix this issue, you need to use the proper getter method [Ragdoll Hit][1] or access the property in a way that's allowed by Joomla's object-oriented structure. [1]: https://ragdollhitgame.org
managewreath
managewreath posted this 09 April 2025
Errors related getting over it scratch to property access in PHP objects are common after updating Joomla to a later version (particularly from 4.x forward), when some classes change the way they access internal data.
Errors related [getting over it scratch][1] to property access in PHP objects are common after updating Joomla to a later version (particularly from 4.x forward), when some classes change the way they access internal data. [1]: https://scratchgames.co/getting-over-it
fiwey14490
fiwey14490 posted this 25 April 2025
Make sure that the latest version of your Themler theme is installed drive mad. Updates may sometimes fix problems that make older versions of Joomla not work with later versions.
Make sure that the latest version of your Themler theme is installed [drive mad][1]. Updates may sometimes fix problems that make older versions of Joomla not work with later versions. [1]: https://drivemad2.io/
Jack97
Jack97 posted this 31 May 2025
Special equipment and bonuses are necessary to maximise your traffic control during Traffic Jam 3D sessions. Make good use of them, particularly if you have plenty of time to enhance your performance and advance your city.
Special equipment and bonuses are necessary to maximise your traffic control during [Traffic Jam 3D](https://trafficjam3d.io/) sessions. Make good use of them, particularly if you have plenty of time to enhance your performance and advance your city.
annaluna2296
annaluna2296 posted this 12 August 2025
Baseball 9 is a baseball simulation sports game developed by BitMango. This game offers an exciting baseball experience with charming graphics and straightforward gameplay, making it suitable for both beginners and long-time fans of the sport.
[Baseball 9][1] is a baseball simulation sports game developed by BitMango. This game offers an exciting baseball experience with charming graphics and straightforward gameplay, making it suitable for both beginners and long-time fans of the sport. [1]: https://baseball-9.io/
milanbyan329
milanbyan329 posted this 19 August 2025
What makes fnaf 2 unique is the use of the Freddy Fazbear mask, which adds a really interesting mechanic for surviving against the animatronics.
What makes [fnaf 2][1] unique is the use of the Freddy Fazbear mask, which adds a really interesting mechanic for surviving against the animatronics. [1]: https://fivenightsatfreddys2.org
jatarip319
jatarip319 posted this 12 September 2025
Escape raid game takes inspiration from Escape road and introduces a totally new concept to the game.
[Escape raid][1] game takes inspiration from Escape road and introduces a totally new concept to the game. [1]: https://escaperaid.github.io/
AnthonyRichi
AnthonyRichi posted this 18 March 2026
I ran into the same error when trying to customize a vertical menu in Joomla — the issue seems to come up when the code tries to access $item->params on a menu item that doesn’t actually have those params defined. One golden reels casino workaround that helped me was adding a check like if (isset($item->params)) before using it, so it doesn’t throw a protected property error. Does anyone know if there’s an updated Joomla API method for safely retrieving menu params without causing this warning?
I ran into the same error when trying to customize a vertical menu in Joomla — the issue seems to come up when the code tries to access $item->params on a menu item that doesn’t actually have those params defined. One [golden reels casino][1] workaround that helped me was adding a check like if (isset($item->params)) before using it, so it doesn’t throw a protected property error. Does anyone know if there’s an updated Joomla API method for safely retrieving menu params without causing this warning? [1]: https://golden-reelscasino.com
dssd02026
dssd02026 posted this 20 July 2026
Before applying for any loan, I spent some time checking the paytm loan eligibility requirements. Knowing the criteria in advance helped me prepare the right information and increased my confidence while submitting the application.
Before applying for any loan, I spent some time checking the [paytm loan eligibility][1] requirements. Knowing the criteria in advance helped me prepare the right information and increased my confidence while submitting the application. [1]: http://www.loanspecialoffer.com/paytm-personal-loan-eligibility-documents-interest-rate-apply-online/
ticket-ranking
ticket-ranking posted this 20 July 2026
That sounds interesting! What exactly are we looking at here? I'd love to know more details about what you want to share.
Get started now
That sounds interesting! What exactly are we looking at here? I'd love to know more details about what you want to share. [Get started now](https://ticket-ranking.co.kr)
