the Themler icon is now missing in the wordpress menu so I can't edit my theme. How to solve?
Hi, the Themler icon is now missing in the wordpress menu so I can't edit my theme. How to solve?Last edited 11 November 2022 by marteniskanor
Please make sure you have exported the theme with Themler editor included. If the issue is still present, please refer to the second part of this article:
https://answers.themler.io/articles/65515/themler-themes-issues-wordpress-woocommerce
If you have lost the Themler icon in your WordPress admin and are unable to edit your template, try the following steps:
1. Check plugins: Sometimes conflicts between plugins can cause icons not to be displayed. Deactivate all plugins except Themler and see if the icon appears. If so, activate the plugins one by one to identify which one is causing the problem.
2. Updating WordPress and Themler: Make sure you have the latest version of Incredibox Colorbox Mustard WordPress and Themler installed. Older versions may have compatibility issues that can lead to missing icons.
3. Check Permissions: Check that your user account has sufficient permissions to access Themler features. You should have administrative rights.
It's a text domain. A unique identification for retrieving translated strings.Please try these strategies and let us know if they help.
Regenerate the CSS from your WordPress Dashboard by selecting coreball Elementor > Tools > Regenerate CSS.
On your WordPress dashboard, navigate to Elementor > Settings, then click the Advanced tab and change the CSS print method to internal embedding.
It's a text domain. A unique identification for retrieving translated strings.Please try these strategies and let us know if they help. Regenerate the CSS from your WordPress Dashboard by selecting [coreball][1] Elementor > Tools > Regenerate CSS. On your WordPress dashboard, navigate to Elementor > Settings, then click the Advanced tab and change the CSS print method to internal embedding. [1]: https://coreballgame.io/A text domain it is. The ability to get translated strings using a unique identifier.If you find that these methods work, please share your results with us.
https://answers.themler.io/questions/219052/themler-icon-missing-in-wordpress-menu doodle jump
Feel the stress melt away in chill guy clicker, where you can immerse yourself in a vibrant world designed for relaxation and enjoyment!
Feel the stress melt away in [chill guy clicker](https://chillguyclicker.org), where you can immerse yourself in a vibrant world designed for relaxation and enjoyment!Before you export the theme, double-check that the Themler Monkey Mart editor is included. In the event that the problem persists, see the article's second section.
Before you export the theme, double-check that the Themler [Monkey Mart](https://monkeymart.io/online) editor is included. In the event that the problem persists, see the article's second section.
