Joomla 4 PHP 8.1 0 - Class "Uri" not found
soulless
soulless posted this 30 November 2023
Themler version 570
Message 0 - Class "Uri" not found, appears on new template after adding few elements and saving. Same result with versions 564 and newer...
Themler version 570 Message 0 - Class "Uri" not found, appears on new template after adding few elements and saving. Same result with versions 564 and newer...
27 Comments
CHSNET
CHSNET posted this 04 December 2023
I have the same problem.
Joomla4 and Joomla5 - PHP 8.1
I have the same problem. Joomla4 and Joomla5 - PHP 8.1
haka81
haka81 posted this 05 December 2023
Joomla4 - PHP8.1
I have the same problem. Joomla4 - PHP8.1
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 05 December 2023
Same Problem here!
Themler V 570
Joomla 4.4.1
PHP 8.1.26
Same Problem here! Themler V 570 Joomla 4.4.1 PHP 8.1.26
soulless
soulless posted this 12 December 2023
Dear support,
I just renewed mu subscription few days ago when I saw that Themler was updated, but this error (image below) showing every time I change something and save changes... I tried different versions of joomla (4-5), different versions of PHP (from 7.4.3 to 8.2.13) with same result - same error. It's not browser issue... tried various browsers - same result.
Can you pleases solve this annoying error asap..
Best regards
enter image description here
Dear support, I just renewed mu subscription few days ago when I saw that Themler was updated, but this error (image below) showing every time I change something and save changes... I tried different versions of joomla (4-5), different versions of PHP (from 7.4.3 to 8.2.13) with same result - same error. It's not browser issue... tried various browsers - same result. Can you pleases solve this annoying error asap.. Best regards ![enter image description here][1] [1]: https://x.img.in.rs/Rkl4
AMoell
AMoell posted this 15 December 2023
Same here
Please solve this anyway asap!
Same here Please solve this anyway asap!
Eric-P
Eric-P posted this 17 December 2023
I confirm I have the same error displayed in joomla4 and joomla5.
Werbeagentur Schulz-Design posted this 18 December 2023
Is this starting again?
Why is an update released with errors and then no response again?
I'm starting to think they're deliberately trying to deceive us!
A quick update so that users believe that Themler is still alive, to sell one or two subscriptions on Black Friday, only to then be unreachable again.
WHEN WILL THIS PROBLEM BE FIXED???
I'm very angry!
Thorsten
Is this starting again? Why is an update released with errors and then no response again? I'm starting to think they're deliberately trying to deceive us! A quick update so that users believe that Themler is still alive, to sell one or two subscriptions on Black Friday, only to then be unreachable again. WHEN WILL THIS PROBLEM BE FIXED??? I'm very angry! Thorsten [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info
CHSNET
CHSNET posted this 18 December 2023
Ich weiß der Support ist grottenschlecht, aber eine erste reaktion zu diesem Thema gibt es in diesem Post:
https://answers.themler.io/questions/224495/themler-has-stopped-working
Ich weiß der Support ist grottenschlecht, aber eine erste reaktion zu diesem Thema gibt es in diesem Post: https://answers.themler.io/questions/224495/themler-has-stopped-working
Eric-P
Eric-P posted this 18 December 2023
Other error if you do "insert/More/Search" as search control which doesn't work, it doesn't search anything.
Joomla 4 Php8.1
Other error if you do "insert/More/Search" as search control which doesn't work, it doesn't search anything. Joomla 4 Php8.1
plonkarchivist
plonkarchivist posted this 21 December 2023
I can verify that I encounter the same error in both Joomla 4 and Joomla 5. vampire survivors
I can verify that I encounter the same error in both Joomla 4 and Joomla 5. [vampire survivors][1] [1]: https://vampire-survival.com
larsenlola06
larsenlola06 posted this 21 December 2023
@drift hunters I am preparing on a parallel domain to upgrade to joomla 4.
@[drift hunters][1] I am preparing on a parallel domain to upgrade to joomla 4. [1]: https://drift-hunters.io
jeanmarcvieux
jeanmarcvieux posted this 29 December 2023
Same here
Same here
jeanmarcvieux
With a little workaround I found that; (it's OK on my side)
Open your the page home_1.php in /templates/name-of-your-template/templates/
At line 5 between PHP tags copy :
defined('_JEXEC') or die;
use Joomla\CMS\Factory;
use Joomla\CMS\HTML\HTMLHelper;
use Joomla\CMS\Language\Text;
use Joomla\CMS\Uri\Uri;
Save it and it's done.
Hello, With a little workaround I found that; (it's OK on my side) Open your the page home_1.php in /templates/name-of-your-template/templates/ At line 5 between PHP tags copy : defined('_JEXEC') or die; use Joomla\CMS\Factory; use Joomla\CMS\HTML\HTMLHelper; use Joomla\CMS\Language\Text; use Joomla\CMS\Uri\Uri; Save it and it's done.
jeanmarcvieux
Themler version 570
Do the same thing with other page like default, page# and blog.
Be carefull you have to add this each time you save the template.
I'm still working how to add this in the template
> Themler version 570 > > Message 0 - Class "Uri" not found, appears on new template after adding few elements and saving. Same result with versions 564 and newer... Hello, With a little workaround I found that; (it's OK on my side) Open your the page home_1.php in /templates/name-of-your-template/templates/ At line 5 between PHP tags copy : defined('_JEXEC') or die; use Joomla\CMS\Factory; use Joomla\CMS\HTML\HTMLHelper; use Joomla\CMS\Language\Text; use Joomla\CMS\Uri\Uri; Save it and it's done. Do the same thing with other page like default, page# and blog. Be carefull you have to add this each time you save the template. I'm still working how to add this in the template
CHSNET
CHSNET posted this 29 December 2023
Unfortunately it only works for a short time. After the upload, Themler automatically carries out an online update and the error is there again.
jeanmarcvieux
jeanmarcvieux posted this 30 December 2023
I've the solution now:
From home then settings add in the field additionnal head html between PHP tag :
"<?php" use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri; "?>"
Just withdraw the quote around PHP tag.
You can add it even if the error is in the editor. Add the lines and save.
capture
It's now OK on save
It is still unacceptable that THEMLER would allow such an error to persist. I looked for a different way to add it but couldn't find anything.
If someone knows how the app add code to the page let us know the way to add theses lines.
@themler: please add it asap
> Unfortunately it only works for a short time. After the upload, Themler automatically carries out an online update and the error is there again. I've the solution now: From home then settings add in the field additionnal head html between PHP tag : "&lt;?php&quot; use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri; &quot;?&gt;" Just withdraw the quote around PHP tag. You can add it even if the error is in the editor. Add the lines and save. ![capture][2] It's now OK on save It is still unacceptable that THEMLER would allow such an error to persist. I looked for a different way to add it but couldn't find anything. If someone knows how the app add code to the page let us know the way to add theses lines. @themler: please add it asap [1]: https://intelartifice.fr/capture.png [2]: https://ibb.co/M5PvbtJ
annawood954
annawood954 posted this 01 January 2024
Common side effects of Kamagra Oral Jelly may include headaches, flushing, indigestion, nasal congestion, and changes in vision. More serious side effects are rare but can include prolonged erections (priapism) and sudden vision or hearing loss. If you experience any unusual or severe side effects, you should seek medical attention.
Common side effects of [Kamagra Oral Jelly][1] may include headaches, flushing, indigestion, nasal congestion, and changes in vision. More serious side effects are rare but can include prolonged erections (priapism) and sudden vision or hearing loss. If you experience any unusual or severe side effects, you should seek medical attention. [1]: https://sexmedz.com/product/kamagra-oral-jelly-100-mg/
codgerchervil
codgerchervil posted this 03 January 2024
I saw a similar problem in this post:
https://answers.themler.io/questions/224495/themler-has-stopped-working pumpkin panic
I saw a similar problem in this post: https://answers.themler.io/questions/224495/themler-has-stopped-working [pumpkin panic](https://pumpkinpanic.com)
jeanmarcvieux
jeanmarcvieux posted this 03 January 2024
just copy past what I wrote and it's done
> I saw a similar problem in this post: > https://answers.themler.io/questions/224495/themler-has-stopped-working [pumpkin panic](https://pumpkinpanic.com) Hello, just copy past what I wrote and it's done From home then settings add in the field additionnal head html between PHP tag : "&lt;?php&quot; use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri; &quot;?&gt;" Just withdraw the quote around PHP tag. You can add it even if the error is in the editor. Add the lines and save.
Werbeagentur Schulz-Design posted this 27 February 2024
Hello jeanmarcvieux
Thank you for your great help.
Unfortunately it doesn't work for me. Maybe I'm doing something wrong too.
I used the following code (e.g. at home_1.php) from line 4:
    <?php use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri;
    $base = $document->getBase();
    if (!empty($base)) {
        echo '<base href="' . $base . '" />';
        $document->setBase('');
Unfortunately the error still exists.
Did I do something wrong?
Many thanks for your support.
Best regards
Thorsten
Hello jeanmarcvieux > From home then settings add in the field additionnal head html between PHP tag : > "&lt;?php&quot; use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri; &quot;?&gt;" > Just withdraw the quote around PHP tag. Thank you for your great help. Unfortunately it doesn't work for me. Maybe I'm doing something wrong too. I used the following code (e.g. at home_1.php) from line 4: <?php use joomla\cms\factory; use joomla\cms\html\htmlhelper; use joomla\cms\language\text; use joomla\cms\uri\uri; $base = $document->getBase(); if (!empty($base)) { echo '<base href="' . $base . '" />'; $document->setBase(''); } ?> Unfortunately the error still exists. Did I do something wrong? Many thanks for your support. Best regards Thorsten [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info
